NX motion link around closed loop/ track
Hi
i have a joint spline which I want to use a my loop or track. An object is defined as a link and I used to joints (Point on curve)
to define the objects position on the curve. How do I now simulated
the object moving along the curve with a constant speed?
Norman
Norman
RE: NX motion link around closed loop/ track
however there was no solution mentioned as to how I can add a proper driver which always ensures a constant speed. The object is actually driven by chains however the chain is laid on s curve/ closed loop.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
