local shell stresses from pad/lug/leg welded to shell?
I am looking into putting legs onto the cylindrical shell of a vertical vessel. My understanding is that the vessel will not fall under ASME codes, because it will be pressurized to a maximum of 1.3 bar (absolute) during operation.
There will be reinforcing pads attached to the cylindrical shell by welding the reinforcing pads around their perimeters onto the shell; then, lugs will be welded to the reinforcing pads; finally, legs will be welded to the lugs.
My question is, how should I approach the analysis of local stresses within the cylindrical shell due to horizontal loading on the shell/pad/lug/legs?
The horizontal loading is from ASCE-7 seismic loads.
In the handbook by Megyesy, there is a section regarding analysis of shell stresses due to vertical loads acting on pads/lugs; can that be adapted to horizontal loads?
I have heard of a WRC 107 bulletin, but I am looking for an alternative resource, before shelling out ~300$ to access WRC 107.
Any help/advice appreciated
RE: local shell stresses from pad/lug/leg welded to shell?
It appears to me that you got a vertical load (the vertical PV) being supported from below by a small cantilever of the vertical legs-lugs-pads offset, but that's all. Are you thinking of his (Megyese's) horizontal loads from wind/seismic conditions?
The horizontal loadings are seismic design forces from section 13.3.1 of ASCE 7-10
(see: http://boo
Although Megyesy, and Moss's books have methods for analyzing horizontal loads on lugs and legs, I am looking for methods to analyze horizontal local loads applied to the shell itself, in addition to the pressure and vertical loads (weight) already acting on the shell.
Welded Steel Tanks for Oil Storage - APPENDIX P—ALLOWABLE EXTERNAL LOADS ON TANK SHELL OPENINGS
