Forces from a floating structure.
The freely floating dock has six degrees of motion: heave, sway, surge, pitch, yaw, roll. Assuming a floating dock will be held fixed to a structure cantilevers at both its ends while in the water. What forces/loads these two connections will receive to hold the floating dock in fixed position. I need loads to design these two connections.. I'll appreciate your feedback..
