MESHING SURFACES...
MESHING SURFACES...
MESHING SURFACES...
Hi i'm a new member here and i have y question about meshing.
I have a problem with a surface model of vertical cylindrical storage tank. I woul like to do a moment analysis on the the shell of the tank, and i have a problem with meshing and conecting the surfaces betwen two shell plates.
Any suggestions?
RE: MESHING SURFACES...
Heve you tried node equivalence? this would ensure that teh surfaces elements share the same nodes and therefore are connected to each other.
My preferred method for doing this is to project a curve onto the bottom surface where it joins with the top.  Then mesh both curves with the same number and distribution of nodes.  Then use a merge or equivalent command to make all the matching nodes the same node.
Doing "node equivalence," as franc11HD suggested above, may help in satisfying your inquiry.
