540 or 1000 pto
540 or 1000 pto
bushhogging with a 70 pto horsepower tractor ,will using a 540 or 1000 pto driveline make a difference?
RE: 540 or 1000 pto
My dad changed his silage blower from 540 to 1000rpm with a kit that added a step-down gearbox to keep the machine running the same speed. One interesting change was that when it plugged it would kill the engine instead of breaking the shear bolts as it did before.(exact same tractor)
ISZ
RE: 540 or 1000 pto
Mike
RE: 540 or 1000 pto
The farm was sold many years ago so I can not confirm this, but I think the reason the engine bogged instead of shearing the bolts is because Gehl used the same size shear bolts on the 540 and 1000 rpm drive shafts. Obviously at almost twice the speed you are only running at half the torque.
And as far as running the engine at a slower speed, some tractors in Europe have provisions for this. They actually have up to 4 different engine-to-PTO ratios.
ISZ
