ASME IX - Production Assembly Mockup - Fillet Weld Qualification
When would be the most appropriate time to use a production assembly mockup for a procedure qualification for a fillet weld to ASME IX welding?
It seems that if you follow the standard test coupon requirements you get a "golden ticket" for all fillet sizes and base metal thicknesses. If you qualify using a production assembly mockup you only qualify essentially what you test.
What would the reasoning be to use a production assembly mockup? Is it for unusual production shapes, or if you just don't have the proper pieces for the special test coupons?
RE: ASME IX - Production Assembly Mockup - Fillet Weld Qualification
