three Moore Industries 535 controllers, one rosemount transmitter
Can one Rosemount 3051 d/p transmitter supply signal to three Moore Industries 535 controllers? I have a boiler dearator with one level control valve, one make-up level control valve and one emergency dump valve. Each valve has a controller of its own. Can one Rosemount 3051 provide each controller with a level signal?
RE: three Moore Industries 535 controllers, one rosemount transmitter
Check the data sheets for loop loading.
Bill
"Why not the best?"
Jimmy Carter
Make sure the loop supply can drive all three inputs in series (assuming a current loop).
With that in mind I suggested the 30 Volt power supply.
Bill
"Why not the best?"
Jimmy Carter
Or you could use a 4-20mA splitter, which produces two 4-20 signals. This Phoenix Contact model can drive 2 devices. each with 250 ohm input resistance and its input resistance is only 50 ohms:
http://rd
