12MHz Sine to Square IC?
Hi everyone,
I have a 12MHz, 0.8Vpp clip sine wave coming from a VCO and I need to square up this signal to TTL-compatible logic. The TI's CDC3RL02 can do the conversion, but its output is only 1.8V. I will need another level converter to convert it to 3.3V.
Is there any IC out there that can convert 0.8V clip sine wave to 3.3V square wave?
James
James
RE: 12MHz Sine to Square IC?
How is the output jitter with a comparator? What's the advantage of an open collector output?
James
Nice idea VE1BLL.
Other possibilities:
An alternative would be an op-amp to increase the voltage followed by a Schmidt trigger.
Use a dual op-amp and use the first one as an amp and the second one as a comparator.
Keith Cress
