Projecting complex pattern/ sketch onto Cylidrical surface
I am trying to create a silicone sleeve around a cylindrical bottle, the sleeve has a complex floral pattern cut into it. I originally tried projecting each sketch onto the the bottle create a curve- it isn't projecting correctly. I was able to extrude the pattern, and converted it to sheet metal (view attachment) to see if I could roll it in to the cylinder but can't seem to do that either- any tips or help would be very much apprecitated.
RE: Projecting complex pattern/ sketch onto Cylidrical surface
What version of SW are you using?
Can you post the SW part?
