Cache Designated Vault issue
I have a part checked out and modified in my Windchill workspace. I have completed my work, but now when I try to to check the part and drawing back into commonspace I get a failure with the following message: "There is no Cache Designated Vault or active folder for Cache Designated Vault on the Local Master Site"
Has anyone seen this message before and if you have, how do you resolve this?
RE: Cache Designated Vault issue
Sounds like your file system is full. Use the External Storage Administrator tools and look at the vault configuration to see if the folders have been switched to raed-only.
Ben Loosli
