3phase system, unbalance
Dear Guru,
just need some help concerning unbalace load in 3 phase system.
Nomally, I saw only magtitude different between  3 phase but today after check at site on MCC.
I fould the angle diff between Phase A and B is 120 degree but the problem in between A and C is 127 degree why not 120 what is wrong in this system, pls advise.
young eng.
RE: 3phase system, unbalance
Are you measuring voltage or current?
David Castor
www.cvoes.com
120 degrees between phases is nominal.  Many things can lead to off-nominal phase angle separation.  Some are not to worry about, others may be cause for concern.  Without more information it would be hard to tell what you have.
Thanks for your answer.
I measuring current.
The current angles depends on the power factor of the loads.
David Castor
www.cvoes.com
