ASME B31.3 Case Operation no processed CAESAR
Hi everybody!!
I´m a beginner in flexibility analysis on pipe lines. I´m beginning to use the CAESAR II but I have some questions.
It is supposed that all lines (almost more than 99%) must meet ASME Code Requrements. In CAESAR, when you run the analysis for a pipe system, you have at first momment the following cases:
-HYD Loadcase
-OPE Loadcase
-SUS Loadcase
-EXP Loadcase
Why CAESAR II on OPE loadcase mentions that NO CODE STRESS CHECK PROCESSED. It means that it is not necesary to MEET as code says. (I´m talking to ASME B31.3)because in the code says something about sustained and occasional loads. Or I´m getting wrong with something?
Please help!
-HYD Loadcase
-OPE Loadcase
-SUS Loadcase
-EXP Loadcase
Please help!
RE: ASME B31.3 Case Operation no processed CAESAR
The design chapter of the B31 codes isn't that long. Take the time to read and understand that chapter at least. Know the equations especially and what they entail. It will be time well spent.
- Steve Perry
http://www.linkedin.com/in/stevenhperry
This post is designed to provide accurate and authoritative information in regard to the subject matter covered. It is offered with the understanding that the author is not engaged in rendering engineering or other professional service. If you need help, get help, and PAY FOR IT.
Let your acquaintances be many, but your advisors one in a thousand' ... Book of Ecclesiasticus
Thanks StevenhPerry. I gave into account that expansion loadcase is the difference between Operational and Sustained loadcases. In fact, maybe CAESAR will not warn you about NOT MEETING stresses according to code but if in expasion loadcase is high, and I mean that expansion depends on operational loadcase, the result you have will not be passed by ASME CODE even though ASME CODE do not indicate on itself. Am I wrong?
I will review complete B31.3
Thanks!!!
Richard Ay
Intergraph CAS
