Part Family member is revised when used from Reuse Library
Would anyone know why a part family member when added to an assembly from the reuse library would get revised? For this part, we do not have the REV column in the spreadsheet. We're using Tc 8.3 & NX 7.5 MP2. This only happens on one part thankfully. When you add the component and look at the ANT, the component has the next revision level in sequence, but that revision is not in Teamcenter for the part. If you try to only save the work part, the system complains and fails to save. We do not want new revisons for these components. All help is appreciated.
RE: Part Family member is revised when used from Reuse Library
Ben Loosli
