Assembly Cross Hatch in Solidworks
I want to create an Assembly Drawing (Slddrw) with Multiple Hatched Views using Solidworks.
Problem: Aluminum Material is a poor hatching for use in assemblies, so I need to change the hatching in the drawing. Then I need to change the hatching in the other views when I create them.
Question: Is there a way to have the other section views automatically update to the new hatching?
James Z
James Z
RE: Assembly Cross Hatch in Solidworks
Tools options/System Options/Drawings/Area Hatch-Fill
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
"This is expected behavior as the drawing view always takes the material/ crosshatch from the part, depending on which material is assigned. As the default the drawing view is always uses ISO (Steel) when no material is applied. The area hatch option in system options applies to annotations only (manually created hatch)."
I think you cannot edit the material hatches. You have to copy and create a new material which you can customize.
Hardie "Crashj" Johnson
SW 2011 SP 2.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
-Dustin
Professional Engineer
Pretty good with SolidWorks
SW 2011 SP 2.0
SW 2011 SP 2.0
