Design Optimization issues
Hi everyone!
I'm facing two problems with the Design Optimization tool of Femap 10.2 with NX Nastran, namely:
- when optimizing rods subject to compressive loading (therefore producing negative axial stresses), the solver fails if I set a negative value for the design constraint (for example, axial stress from -10 Mpa to 0 Mpa). On the other hand, if I set a positive value (from 0 to 10 Mpa), the solver works but the value of the initial constraint differs from the one resulting from the static analysis; for example, if the static analysis gives a compressive axial stress of -5 MPa, the function "MAX VALUE OF CONSTRAINT" resulting from the design optimization starts from a value of +5000MPa! Always the same value but 1000 times more!
- when optimizing plates, the solver ends up with USER FATAL MESSAGE 4298 and USER FATAL MESSAGE 9069.
Thanks in advance!
Thanks in advance!
RE: Design Optimization issues
Mark
sherman dot mark at siemens dot com
