Acronyms for motor control
In our project the acronyms used on P&ID for motor controls are:
XGM
XSR: run status
XCR: start stop command
XA: common trouble alarm
XA: L/R status
I found these acronyms in "instrumentation handbook" but there is no explanation for them. Can anyone please explain them for me?
RE: Acronyms for motor control
I guess:
 - XGM repesent the motor
 - The rest is self explanatory.
 - "L/R status" means Locked Rotor.It comes probably from the motor protection relay. Basically it means that your motor did not reach full speed in the allowed time.It's a protection.
Hope it helps you a bit.
L/R is equally likely to mean local / remote. Perhaps not so self-explanatory.
These most likely relate to ISA standard notation. P&IDs (Piping & Instrumentation Diagrams) are typically instrumentation centered.
http://www.engineeringtoolbox.com/isa-iso-instrumentation-codes-d_37.html
If there is motor control referenced on it, it is typically only as it relates to an instrumentation / SCADA or DCS system.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
