Trying to find a company to evaluate our generator.
Hello all
I've got white marks on the end turns on one of our generators. I think it may be corona. It is a Brush BDAX 7-290ERJT, 71176 KVA. We have been going through Brush for the last week, had a rep from them out for the last couple days and no answers. I think the white marks are an issue and want a second opinion.
So does anyone know of a company that that can take a look at our generator in California? And hopefully do repairs as neccesary.
Thanks all.
Thanks all.
RE: Trying to find a company to evaluate our generator.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
Look over their website. Ask for Rudy. They go far and wide.
rmw
PS: my $0.02: you got corona, sorry.
rmw
(2B)+(2B)' ?
Is the location of the mark approx 1" from the slot?
If > 6kv and at that location, sounds like degadation at the overlap between the slot-section carbon/semicon and the grading.
(2B)+(2B)' ?
(2B)+(2B)' ?
rmw
Meanwhile, just thinking out loud, since grading layer is supposed to slope the voltage gradually from ground voltage at core end to line voltage at outer end, maybe the effective resistance of that grading layer is way too low for some reason, resulting in outer edge of grading being too near ground.
(2B)+(2B)' ?
Some of the spots look like, from what I understand, classic corona. White to a little yellow, starting at a point and a 'V' pattern away.
Other spots just look like a patch of white, almost pure white.
Electricpete, thats the best idea I've heard so far.
1 – It does not appear to be a tight area. Typical pd due to coils too close occurs at tight areas where coils cross over each other, where jumper is adjacent to coil, where blocking bridges coils etc... none of these appear to be the case.
2 – It is about 6" outside the slot where the end of the grading would be. And your OEM rep said something like it was the end of the "shield" .... can't think what else he would be referring to.
3 – It appears to be a generally circumferential pattern (*although perhaps you can check this better for yourself than we can check from the pictures*). Traditional pd due to close spacing does not follow a circumferential pattern. But circumferential pattern is expected at edges of stress treatments if they malfunction in a manner to create voltage difference at that edge.
The more typical malfunction of a stress treatment occurs at the junction of the semicon = carbon and the grading = SiC.. It gives a circumferential band about 1" outside the slot. This degradation can progress in 2 stages (as well detailed in "Electrical Insulation for Rotating Machines" by Greg Stone, Ian Culbert, etc al):
Stage 1: Burning occurs due to surface current flowing from endwindings to the slot. In the endwindings, the circuit to the conductor is completed through the winding capacitance. (I think endwinding conductive contamination will tend to increase this capacitance by the way). So we have current flowing and it is relatively small, but the heating occurs at a local high-resistance area which is the interface where the current must transition from one layer to another. Eventually the heating from this current burns the stress treatment open to create an open circuit, which leads to stage 2:
Stage 2: A voltage difference appears across the open circuit created by stage 1. Surface partial discharge occurs due to this voltage difference.
Again all of the above is well documented for the interface from semicon to grading, but I have never heard of anything like it at the outer edge of the grading (the endwinding side). We could reasonably guess that there are 2 possible mechanism for damage at this location (outer edge of the grading) that resemble the 2 possible mechanisms of stage 1 and stage 2 above. The two possibilities are:
1 – burning due to current which is passing from the outer surface of the endwinding, possibly through a coating / paint layer, down into the grading layer. This type of burning could discolor the coatings to create the yellow or other colors.
2 – surface partial discharge at the outer edge of the grading. It is harder to come up with a reason for this since it is not really analogous to stage 2 above. The best I can come up with is what I had suggested in the previous post.... if effective resistance of grading is too low than you could end up with a surface voltage different at the outer edge of the grading which creates partial discharge.
If it were one of our critical machines, I would call Dave Scherer of IPS LaPorte for his opinion. We have paid him several times to travel to other repair shops to provide his opinion on various visual partial discharge symptoms to help us figure out what we should do.
(2B)+(2B)' ?
I can tell you that Brush England speaks a different English than USA folks. Same language, different words or different meaning for the same words. I can't remember what they called this conductive tape. If I heard it I would remember it. Shielding doesn't ring a bell.
Ask your "rep" what those metal things on the end of the rotor are. If he says 'end caps' he is a Brit. If he says 'retaining rings' he is an American. If he says 'end caps' with an american accent, be suspicious of his/her background.
In either case, as I am acquainted with the rep that used to cover that area for Brush, I can state that this 'rep' must be a fairly recent addition to the Brush crew.
See if you can find out who did the report from the home office.
What vintage is this BDAX unit?
rmw
The moisture isn't really an issue here.
The generator was manufactured in 2002, and been in service since 2005.
rmw
I will say that if I had your problem, he would be one of my first choices to call.
rmw
We may call him back for future generator issues though.
I almost recommended him (his firm) to you when I made the recommendation above, but thought that he might be too far away from your location for you to consider so I didn't. Ironic that you encountered him anyway. He is a solid individual.
The firm that I did recommend would be his competitor.
I am a little surprised by Brush's approach. Is the Insulation Engineer you refer to named "H" too, the same name with that first letter; second name begins with "L"? If so, he pretty well knows his stuff, but remember that he is a factory guy and as such has a different view of things than someone like "H" who does nothing but fix-em day in and day out.
rmw
Your last post made it clear that it is the rotor that they are recommending be removed and cleaned. Is it dirty or oily?
I'll come do it for 200K. (see tongue in cheek.) You would be well on your way to buying a new one at that price.
rmw
My manager and I considered doing it for $200,000.
(2B)+(2B)' ?
The reason I won't answer is that I have seen oil dripping from so much of the entire endwinding area that I hardly noticed any on the dolls eyes. And... I actually don't know what the piece is called in USA English.
Justatech, depending on the driver, oil leakage can be caused by problems with the vent mist elimination system as well. One particular popular model uses a filter that will cause the generator bearings to puke oil oint the endwindings if it is not serviced regularly. Based on the generator model you quoted in the OP, it is highly likely that you have one of these.
rmw
It's the funnel-shaped region of the endwinding outside the stator core. Viewed end-on from a distance the endwinding has a vaguely woven appearance, with a hole in the middle where the rotor would sit. I guess that's where the name comes from. Interested to know if rmw's recollection is the same - it's a phrase I've picked up along the way and have never seen it referred to in a text.
In the end winding area, the end windings are tied to (non conducting - bakelite?) braces with string (cord, twine) and the string is tied through those brackets and braces with holes in them. There are 4-6 (been a while) large flat brackets that are attached to the end of the stator that stick out axially from end of the frame which are shaped at an angle that follows the angle of the winding as it leaves the stator. That bracket has a row of holes in it into which is threaded the twine that is wrapped around the end windings to bind them to the bracket. The holes in those brackets and the other various pieces like it to which various parts of tne end windings are secured are referred to as the "dolls eyes".
That is why I didn't quite understand your use of it with respect to the oil dripping, as the oil drippings I had seem were all over the end windings not limited to just the bracketry with the dolls eyes.
I don't know if that is a Brush term or an industry term, but I suspect it is the former.
It does blow my mind as a ME that a machine as powerful as a generator would be held together by string and tape. We certainly don't build the turbines that drive them that way.
rmw
rmw
I can't remember if one of these last two posts are the "dolls eyes" or both, but one is for sure.
String.....?????
rmw
www.qinetiq-na.com
Looks like we are going with Electrical Maintenance Consultants (EMC) out of Rocklin, CA. They've done a lot of work with the other small municipal utilities in the area.
I've added all the other companies info to a list we have going around here.
Thanks again
