Relief Requirements for Low Pressure Coded Vessel
I have the following question for use of a pressure vessel in a code state: For a code-stamped, pressure vessel, if the intent of use of the vessel is at atmospheric pressure, is a relief device mandatory if the code-stamp is removed and documentation generated to say the vessel is considered a non-code vessel? In other words, does the requirement of a relief device apply to a vessel operated or potentially operated (emergency situation) at pressures above 15 psig or does it apply to a vessel constructed to withstand pressure above 15 psig, regardless of the application?
RE: Relief Requirements for Low Pressure Coded Vessel
If the intention is atmospheric operation, then the relief device will be a piece of pipe connected to atmosphere, perhaps through a trap or other device. That's a perfectly valid relief device.
A vessel entirely without relief device, which in a credible emergency scenario may exceed 15 psig, needs that credible scenario dealt with somehow. If it's dealt with by design, i.e by giving an MAWP above 15 psig to account for the calculated max pressure the scenario can produce, then it's ASME and you're forced to have some sort of relief device on there.
Of course, this is not a justification for amateur lawyers to evade common sense, which I think is the point that moltenmetal was getting at.
Trottiey, If my situation lacks common sense, I believe you gave the perfect answer.
