Single Inlet FDC
Single Inlet FDC
13 2010 6.8.1.3 states that I can use a single butt fdc where the riser is 3" or smaller. I was sure there was a code reference somewhere stating that the fire dept. supply line had to be at least the size of the riser, but I can't find it in the 2010 edition. I'm thinking I am good to go with a 3 x 2 1/2 mech tee off the riser and a 2 1/2 check valve. This is one of those times the electronic version with the keyword search would come in handy!
Thanks in advance.
Thanks in advance.
RE: Single Inlet FDC
