Default Tolerances
Default Tolerances
Ok I give up - I want to change the default tolerances for my parts in Pro/E Wildfire 5 (soon to be Creo 1). I want three decimal places to go to +/- .005"
I've placed the following tag in my config.pro: "linear_tol_0.000 .005"
but in the corner of the screen (tolerance display enabled) it still says "x.xxx +-0.001"
Is my syntax wrong? Does this option live somwhere else inside my part template?
RE: Default Tolerances
Honestly I'm not even sure how to change the defaults on a part level, although I can modify them individually (as long as it's outside of sketch mode, that one took me a while to work out)
linear_tol 3 0.005
How can I change the defaults in a template or part at the local level?
The only way I know to change the ones that are not shown is to make a drawing and create a note with the parameters. Then you can change the value in the note which changes the value in the model.
&linear_tol_0.0000 in a note would display as the default tolerance on a 4 decimal place dimension.
