Evaporator fan power Calculation
I am actually calculating the total heat load on a freezers room and dont want to guess the heat load by fans. Can someone help me with the tip I will use to calculate the Heat load by evaporator fans in KW. I need to know how to determine the power requirement of the evaporator fans I will need during design. Is there any table where I can read pressure drops?
RE: Evaporator fan power Calculation
English units: 10 bhp x 2545 = 25,450 btu/hr
ht
