Changing material during analysis
I want to change the material properties of a partition of my model during the analysis. (It is a 2D model with a hyperelastic material.) An old thread to this topic (http://www.eng-tips.com/viewthread.cfm?qid=105599) states that there are two ways of doing this:
-- using the *FIELD option (which can cause convergence difficulties if there is nonlinearity)
-- defining two distinct sets of elements on the same partition, assigning the sets to different materials and switching between them with *MODEL CHANGE, REMOVE/ADD
I am trying to use the second method because there are nonlinearity and large displacements.
THE PROBLEM IS:
The sets which I can select in the section assignment tool in order to assign them to the distinct materials have to be geometry sets (and not element sets). Therefore, I use geometry sets (named set-a and set-b). Furthermore, Abaqus does not recognize the sets properly when it comes to removing them: *MODEL CHANGE, REMOVE Part_name.set-a removes both set-a and set-b so that there remains a whole in the model. In addition, there is no difference between adding set-a or set-b with *MODEL CHANGE, ADD. In both cases Abaqus adds the set which has been defined last in the section assignment tool.
Can anyone help me??
Thanks in advance!
Philipp
THE PROBLEM IS:
Thanks in advance!
Philipp
