SWX 2008 macro needed
I'm looking for a macro that will link all available drawing views in a SLDDRW file to a BOM table in the same file. Does anyone know of such a macro or is able to provide one? Thanks in advance for any help you may be able to provide.
Dave Lehman
Dave Lehman
RE: SWX 2008 macro needed
Deepak Gupta
SW 2010 SP4.0 & 2011 SP1.0
DriveWorks Pro 7 SP5
Boxer's SolidWorks™ Blog
I'm not sure if I've explained this clearly. Does this make sense to you? What I need is some way to automate checking those boxes and selecting the proper BoM for all views on all sheets in the active drawing file. (There is only one BoM in each drawing, but their names vary from one drawing to the next.)
Again, thank you for any help you may be able to provide me.
Don't you hate that! The SW default is to not check the box "Keep Linked to BOM" when a view is created. Attached is a macro that finds all the views on all the sheets associated with the BOM. It's set up for SW 2007. Sorry I never had a copy of SW 2008, so I can't change the library references for you. If you don't know how, maybe some nice helpful person on this forum will do it for you
Enjoy
Tobin Sparks
www.nov.com
htt
http:/
http://www.youtube.com/watch?v=xkUxIwn1j2Q
