Searching/Selecting Deactivated Features In The Specification Tree
Using Catia V5R19;
Is there a way to select deactivated features in the part workbench specification tree using the "Search" command?
Any response will be greatly appreciated!
RE: Searching/Selecting Deactivated Features In The Specification Tree
Procedure To Searching/Selecting Deactivated Features Using The "Search" Command;
1."Search"
2.Click "Advanced" tab
3.Under "Workbench", select "Part Design"
4.Under "Type", select "PartDesign Feature"
5.Under "Attribute", select "Activity"
6.At the "Attribute Criterion" prompt, select "Activity =FALSE"
7.Click "OK"
8.Click "Select & Search" (Features become highlighted)
You can use Tools --> Parameterization Analysis
Set the filter to Inactivated Features.
Derek
Hi Ferdo,
in your link adress above, download link dont work with right click and save. It's saved an htm that open unreadeble document.
Marco
It seems is not working like I expected (at least in Firefox), so right click and save link as...
Fernando
cadromania.net - Romanian CAD forums
Always open htm document
Marco
