3 hour storm duration
Can someone please cite the reason that a design load is based on its maximum value during 3 hours of a 100-year storm? In other words, why is the storm duration assumed to be 3 hours. Is the most intense period of a storm expected to last 3 hours, even though the synoptic time scale of storms is longer (3-5 days)? Or is 3 hours chosen because Hmax ~ 2*Hs? I would really like to see a technical explanation of the 3 hour interval. Thanks!
RE: 3 hour storm duration
"Over an interval of 3 hours the statistics do not change very much and the seastate may be described by significant wave height (Hs) and mean zero crossing period (Tz)."
"Three hours has been introduced as a standard time between registrations of sea states when measuring waves, but the period of stationary can range from 30 minutes to 10 hours."
DNV-RP-H103 mentions 3 hours as well.
Remember the 1.86 factor which is said to be the ratio between max wave height and sig wave. I've used that for years without complaint.
So I guess the stats people think that after 3 hours you just see (statistically) a max wave height that doesn't differ much from using say a 4hour, 5hour... 10 hour etc. storm data.
However for some analysis (e.g. Fatigue analysis), if you can prove that a time duration less than 3hrs will give results that are statistically ok compared to the 3hrs, it will be acceptable.
