Copying text out of string without deleting previous text.
I need to read in data from an engine, the meter sends :
B+105#H+500#C+200#D+100#A+100#F+250#G+50# through the serial port. I need to find each channels value without deleting the previous text. Pos(Letter, String) works fine but pos(Hash,String) only finds the 1st Hash.
Function works fine that I wrote, except it takes too long
copying the buffer to 8 channel variables and then deleting everything in front of the letter used and then converting it into numbers that I can use. How can I get the text I want with only one buffer and one variable.
Any suggestions?
RE: Copying text out of string without deleting previous text.
What kind of CPU, language do U use ? What does # and the letters mean ?
<nbucska@pcperipherals.com>
