Flare Towers and Booms (ISO 19901-3 A.8.4)
Equation A.6 located in ISO 19001-3 section A.8.4 looks incorrect.  If L=8 m then the D>(8^2*7000)^(1/3)=76.5 m.  That it is patently rediculous.  Does anyone no where this equation comes from, or preferably, what the correct equation should be.  It seems as if the diameter should be in mm or there should be a decimal place in the 7000 value, but I haven't been able to find any references.
