Fatique Testing
Fatique Testing
I have been asked to determine the velocity/range of velocities during cycle testing in order to size the pump required.
The specs are as follows amplitude varies from 0-500 psi frequency varies from .5 to 30 hz. The pressure and frequency will be set by the end user depending on his/her test requirements.
I am not sure what governing equations to use. If someone could help guide me I would greatly appreciate it. Thank you.
RE: Fatique Testing
Let your acquaintances be many, but your advisors one in a thousand' ... Book of Ecclesiasticus
RE: Fatique Testing
RE: Fatique Testing
RE: Fatique Testing
RE: Fatique Testing
RE: Fatique Testing
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
RE: Fatique Testing
Thank you.
RE: Fatique Testing
