Suggestions to improve velocity of a macro
This post is not to know a particular command or procedure, but it is to know if there is
a specific methodology to make a macro faster: for example, use a few comments, use a single command that includes many features, or rather many commands with a single function or things like that.
RE: Suggestions to improve velocity of a macro
This depends on what you want to do, in which workbench are you working, what are you using (catscript, catvba)...hard to say something...but generally speaking applying vba rules should be good enough.
Comments are good to clarify your code for later use (by you or others).
Fernando
cadromania.net - Romanian CAD forums
