Section VIII jobs
Section VIII jobs
This maybe a vague question but any input on this is greatly appreciated. What would be a good stratergy on going about to look for jobs related to ASME Section VIII. Is there some online directory dedicated to B&PV industry?
Thanks in advance.
Jaspreet Hothi P.Eng.
Thanks in advance.
RE: Section VIII jobs
From what university?
Have you had any real time experience in designing of pressure vessels?
rmw
Thanks for your input.
http:
http
Could you be more specific as to who or what law or regulation requires ASME stamps in Canada?
cool... why would you want to be grubby PV engineer? That sounds cooler.
As a P.Eng. who hasn't actually worked in Canada, as far a ASME Code and their role in Canadian jurisdictions, I believe it isn't that straight forward as noted by Ted Leblanc here: ht
Since I'm register in Alberta, I'll refer to the province of Alberta and the applicable Regulation 49/2006 of the Safety Codes Act Section 6 which states the codes in force of which subsection(d) ASME VIII-1:2007 (e) ASME VIII-2:2004.
As far as stamping, this is covered in Section 28(2) ASME code stamp not required if manufactured in Canada (3) ASME code stamp required if manufactured outside Canada.
