Kinetics of a released elastic band
My problem is to calculate the final velocity of a small mass, m, tied to the end of an elastic band that is pulled and released. I know how to do this in the simple case: potential energy of the elastic (spring)equals kinetic energy of the mass. The challenge is that the mass of the elastic band may be significant in that it too will have significant kinetic energy so that the final velocity of the small mass will be less if the band soaks up kinetic also. [The elastic of course stretches and the elemental kinetic energy varies along its length]. Any ideas?
RE: Kinetics of a released elastic band
If a mode shape is defined by a function Phi, then the effective mass is equal to the integral of (mass per unit length) times Phi^2, integrated over the length. In your case, Phi(x) = x, m = mass/length, and effective mass is m*L/3.
F=100(DeltaL/OrigL)/(Elonation%*TensleStress*Area)
