voltage variation tolerances
What is the statutory percent voltage variation in Europe for 400V 3 phase 50 Hz system?
RE: voltage variation tolerances
EN 60204-1 sec. 4.3.1 Electrical Supplies
The electrical equipment shall be designed to operate correctly under full load as well as no load with the conditions of the nominal supply as specified below.....
A.C. supplies
Voltage: Steady state voltage of .9 - 1.1 of nominal voltage.
Voltage Dips: shall not exceed 20 % of the peak voltage of the supply for more then one cycle. There shall be more then 1sec between successive dips.
Frequency: .99 - 1.01 of nominal frequency continuously,
.98 - 1.02 short-time.
David Baird
dbaird@gemcity.com
Sr Controls Engineer
EET degree.
Journeyman Electrician.
Thank you David.
rajiv krishen
This information is correct.  To get a CE mark on your device, you'll have to design it and have it tested to that standard.  This means that your device will have many tests performed at 440 VAC.
