Moldflow vs. Moldex 3D??
Hi people.
My company are thinking of bying a simulation app for injection molding simulation. Its either gonna be Autodesk Moldflow og Moldex 3D.
Does anyone have any experience with these apps?
Which one comes out with the most reliable results etc?
We use SolidWorks for CAD by the way.
RE: Moldflow vs. Moldex 3D??
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
which one of Moldflow or Moldex3D would you recommend?
Chris DeArmitt PhD FRSC CChem
I only ever used Mouldflow so I can't compare directly. I have worked on numerous projects where mould flow analysis was done by others with non disclosed software, hence my comments.
I have seen Mouldflow not work, but on investigation:-
The wrong material was used.
The wall section had a thick spot on the mouldbut not on the model.
The gate was positioned in a spot that was impossible to manufacture so the mould would open.
The gate aimed directly dow a cavity giving bad jetting, etc etc
Pat
for site rules
I can say that we have tested both software and the conclusion was, that for thermoplastic flow simulations both works OK. By themosets we found major discrepancies.
Nevertheless if you are just in thermoplastic area commercial criteria should be put on first.
Best regards
