Surface cracking after liquid nitriding
We've recently run into a problem with surface cracks occuring in nitrided parts both during the nitriding process, and in during proof loading of the parts. Of the 8 parts which we sent out for liquid nitriding (the ARCOR process), 1 came back with cracks on the surface and another 4 deceloped similar surface cracks during their first proof loading (well below yield strength). The cracks travel circumferentially around the part at some of the locations of the highest stress concentrations. I've run an FEA case to simulate the proof loading, and no plastic strain is generated at this location. The part is made from a single piece of 9" 4330-V-mod round stock.
During the nitriding process, we've been assured that our parts are sufficiently clean, the process is run as designed and no thermal shocks are encountered. Neither the owner of the ARCOR process, or our nitriding outfit can provide us with any information regarding the cracking, and I can find no resources which can explain why cracking occurs or how to prevent the cracking.
I don't yet have the results, but we're sending the parts out to get a micrograph of the cracks to determine if the cracks occur before/during nitriding, or after removal from the liquid bath.
Any insight into the cause of the cracks would be useful. Would gas nitriding produce more predictable and desirable results (single or double stage)?
Thanks!
Thanks!
RE: Surface cracking after liquid nitriding
-The nitriding outfit insists sufficient surface cleaning was done.
-The solvents they used shouldn't have caused any harm to the material.
-Nitriding bath @ 570°C for 1.5-2.5 hours
-Oxidizing bath immediately after nitriding (350-400°C) for 20 minutes
-Water cool (near ambient) before bead blasting
-Oxidizing bath and water cool again
Our nitriding outfit says this procedure was followed, but I doubt there is any way to know for certain if the procedure was followed exactly. I don't think the parts were cooled too quickly, but the possibility of remaining at a high temperature for too long sounds interesting.
We spec our tempering temperature to be above 593°C. We don't spec a tempering temperature and time however, we specify a set of material properties and a tolerance and tell the heat treater to obtain them. Looking back at some MTR's from different manufacturers, tempering temperature has been between 600 and 625°C and tempering time between 5 and 8.5 hours. The stock being tempered is approx 8" diameter.
William Gunnar
http://www.IndustrialCoatingsWorld.com
