Part list not updating correct
In an assembly i did a "Replace Component". After that, when updating the drawings the part list no longer showed correct information. The replaced component is mentioned twice with different Item numbers. Description is the same in both of them but drawing number is the old in one and the new in the other.
Part list says there is 3 of the new component and 1 of the old but i have checked the assembly and the old component does not exist anymore.
RE: Part list not updating correct
Do a rmc (right mouse click) on the upper left corner of the parts list > update parts list
My part list got these columns. No of, Item no, Description, Drawing no/Article no, Weight.
The information in the part list is
12, 9, Screw MC6S, 000407, 0
4, 13, Screw MC6S, 000421, 0
The correct information should be
16, 9, Screw MC6S, 000421, 0 (The item number can change)
Haven't played with PLs since V18, but we used to have an issue with changed numbers not updating correctly.
Ben Loosli
It did occur to me that HSE_SOURCE_ITEM_NO was set to same in both screws for a short period of time when i did the "replace component" but this is not the case now. Maby also HSE_SOURCE_DESCRIPTION was the same.
I also tried changing names of some parts in Teamcenter just to see if the part list would update and it did but 000407 will not go away.
I tried renaming some parts in Teamcenter and it seems like if HSE_SOURCE_DESCRIPTION of the part is set to the same name as Name then the part list will be messed up. I dont know if this is a coincident.
Is there no way to reset the partlist to default or something?
