NX 7.5 Motion Simulation movie export as MPEG, How change Resolution?
I'm running NX 7.5. I have an animation in motion simulation then I go File>Export>MPEG and export it as an MPEG my problem is that the movie exported is always 352x240 pixels with a frame rate of 23.976023. I doesn't matter if I have the program in full screen or just a fraction of the screen.
I need a "bigger" video output, How do I change the definition of the output for MPEG in Motion Simulation?
Another constraint is that it has to be MPEG because I'm exporting the video to other program that only accepts MPEGs
Thank you for all your help.
RE: NX 7.5 Motion Simulation movie export as MPEG, How change Resolution?
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6.0.5.3
In the movie tool, as far as I know, the user is the one that start and stops the recording and that introduces the difference in times.
But thank you for your suggestion.
