Welding 17-4ph with low carbon steel
I have to do a fillet weldment between a 2" thickness 17-4ph H1025 plate and a 1 1/2" A36 or 44W plate. Weldment profile is 5/16" wide. I have to elaborate procedure and I'm looking for the better filler metal.
Should I weld on annealed plate and is it safe to make heat treatment (conditioning H1025) after all welding?
RE: Welding 17-4ph with low carbon steel
Plymouth Tube
If not then anneal the 17-4 before welding, and age the whole thing after welding.
You could use 309 for filler, or 17-4, or CS.
Plymouth Tube
