thermally conductive, electrical insulator
I would like to insulate a coil at 400V from a metal case but allow efficient conduction of heat into case. Temperature about 600 deg. C. Power 1-2 kW. Size 2" diameter.
Could you recommend a material that can take and conduct heat and still maintain electrical insulation.
Device is similar to a heating coil but it is for R&D work.
I have seen heating coils surrounded by a powder in a metal shield. Any idea what this powder might be?
RE: thermally conductive, electrical insulator
Any similar substance that I could pot like a resin?
Glass is interesting however cracking might be a problem as well as casting coil in glass might be be a difficult process for a single test.
_____________________________________
"The richer we have become materially, the poorer we have become morally and spiritually." Martin Luther King Jr
It is white, slick like graphite, a fair heat conductor, and a great electrical insulator.
http
Plymouth Tube
DO NOT CONSIDER BERYLLIUM OXIDE EVEN THROUGH IT IS A GOOD THERMAL CONDUCTOR ( material is hazardous !! )
Aluminum Nitride (ALN) is also a strong candidate for a solid but could be expensive.
(used in specialized semiconductor mounting)
TTFN
Chinese prisoner wins Nobel Peace Prize
http://ww
There are greases like thermalloy that might work.
Diamond powder might work like MgO. It is the filler in some products.
Search the forum. This topic is discussed often with different variations.
As used to interface computer CPU's to heatsinks. Completely electrically insulative
Adriaan.
I am a Mechatronics Engineer from South Africa.
www.martin-electronics.co.za
Dik
pushing the upper temperature limit. Schott make also makes
some high temperature glasses that might meet your requirements..
http://www.insaco.com/MatPages/materials.asp
http://www.aximmica.com/mica-sheets.html
http:
