Emtying unloading hose between truck and unloading pump
Hi
Is there any solotion you can share to "complete" emty the unloading hose between the truck and unloading pump after emty the truck, avoiding spillage (in this case acid) when disconnecting the hose.
RE: Emtying unloading hose between truck and unloading pump
Let your acquaintances be many, but your advisors one in a thousand' ... Book of Ecclesiasticus
Maybe here?
When the offload is complete, the garden hose dilutes the little bit of spillage.
There are guidelines available for sulfuric acid offload stations available from the vendors who sell the acid
The TODO connections work great also, though they are high dollar.
I'm not sure if you can blow down an acid line with compressed air.
