Cutting out nozzle and welding new one in over old weld
Has anyone got any recommendations or things I should be watching out for?.
I intend to cut off a 2.5" set in full pen nozzle off a pipe so that the finish is approx a dia2.5" hole flush with the pipe then cut a 3.5" hole offset from the initial CL so that when I set my new 3" nozzle in some of the shell material will be the old nozzle material.
I know it is not recommended practice to be welding through previous weld material like this but it is unavoidable, the code is B31.3.
RE: Cutting out nozzle and welding new one in over old weld
2. Watch out not to be caught, if you still decide to do it on your way.
Cheers,
gr2vessels
I would insert a pup piece and set in a new nozzle or use a Weld-O-Let on the pup.
