Non-Standard (Non-ASME B16.5) Pipe Flange?
Hi all, new user here. Here is my question:
I have a 24" OD SecVIII pressure vessel in our lab that we need a new flange for. The description of the flange on the drawing BOM is [1-3/4" x 28-3/4" OD Plate Flange]. I attached a pic showing the dimensions:
OD is 28.75"
Bolt Circle Diameter is 27"
20 bolts
flange thickness = 1-9/16"
The problem is, the dimensions of it aren't in agreement with ASME B16.5 (Std. for Pipe Flanges/Fittings) for a 24" Class 150 Flange. i.e. according to ASME, the OD should be 32" and BCD should be 29.5.
Is there some other standard that governs this flange? Can flanges be made to non-standard dimensions? Is this allowed for ASME SecVIII vessels?
Your help is appreciated,
Steve
OD is 28.75"
20 bolts
Steve
RE: Non-Standard (Non-ASME B16.5) Pipe Flange?
If no one here has the answer, you might check next forum over at the Boiler & Pressure Vessel engineering board.
- Steve Perry
http://www.linkedin.com/in/stevenhperry
This post is designed to provide accurate and authoritative information in regard to the subject matter covered. It is offered with the understanding that the author is not engaged in rendering engineering or other professional service. If you need help, get help, and PAY FOR IT.
