modifier for RC shearwalls in tension
When is it allowed to use a modifier of 0.35 for walls? From what I know this is done when the wall is in tension. Anyone please give me procedure how this is done in the software itself and if possible, a manual check also. Thanks in advance.
RE: modifier for RC shearwalls in tension
A manual check would be do a P/A - M/S to see if there is a tension in the wall and if it exceeds 7.5 sqrt (fc'). Usually computer programs let you see stress outputs and you can set the parameter to show any stress levels that are higher than the modulus of rupture of concrete (f't)
