Saving new drawing, "description" field already filled in... Bug?
When I save a drawing for the first time, the "description" field is always filled in already with the description of a completely unrelated part I did long ago (the same one each time, ergotron arm mounting plate something or other.) If I don't remember to change it, I'll have a drawing file with the wrong description instead of no description. Anyone know how to fix this? BTW, it only happens when I use the File > Make Drawing from Part command to initiate the drawing based on the part file currently opened.
RE: Saving new drawing, "description" field already filled in... Bug?
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
I usually set up a default template, then enter all the project data and save that as a new template. As a result I have many templates that are similar but not exactly the same.
Hardie "Crashj" Johnson
SW 2011 SP 2.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
