Removing Individual Instances When Using ôReuse Patternö In Assemblies
Using Catia V5R19;
Does this option exist? I'm trying to insert components using a circular pattern from another part but not completely filling up the entire pattern, only in certain locations. Can this be done?
Any response will be greatly appreciated!
RE: Removing Individual Instances When Using ôReuse Patternö In Assemblies
When you want to add/remove instances, go into your locations sketch and add/delete point locations for the instances you want/dont want, this will update your reuse pattern. Just dont delete the point for the original instance and it will work everytime.
