Impeller Trim
Impeller Trim
This seems like a rather basic topic, but I could not find where it has been addressed on these forms.
Question:
When pumps are operated on electric motors, the motors never operate at synchronous speeds due to the principle inwhich they work. (Back EMF demands current draw to compensate for load). Because this effect varies from different types of motors, don't manufacturers need to take into consideration the specific motor that will be used when manufacturers are trying to determine impeller trim? If they do, are impellers trimmed based on full load motor speed, or on some interpolated speed based on motor load at either pump runout or operating point?
I hope this was clear. Thanks for your time.
Question:
RE: Impeller Trim
You should use the speed shown on the reference pump curve.
Are you going to eliminate 2 poles or something?
Let your acquaintances be many, but your advisors one in a thousand' ... Book of Ecclesiasticus
RE: Impeller Trim
RE: Impeller Trim
Motor must be sized for end of curve. Say that is 399hp so you buy a 400hp motor. Your operating point requires 300hp. Shutoff requires 200hp.
Full load speed of your motor is 1180 rpm so the pump curve is set up at 1180. But 3/4 load speed is 1185 and that's the speed the motor is going to run at. 1/2 load speed is 1190 RPM, that can be a pretty large increase in head at shutoff.
RE: Impeller Trim
RE: Impeller Trim
RE: Impeller Trim
Mr GaTech, when the pumps are sized, they are sized to deliver the performance shown on the curve, so the manufacturer has to take into account the reduced RPM due to motor slip. When he sells you the pump and hands you a curve, that pump will have been tested with a real motor, and by some specs with the motor that will operate the pump and the impeller has to be trimmed (if required to be trimmed) to a size that will deliver what the curve says it will.
Most curves I see have a pump rating at a speed slightly slower than synchronous speed, say 1760 for 1800 rpm or 1470 for 1500 rpm.
rmw
