OUT DAMN CUSP!
OUT DAMN CUSP!
Crash course in lofting, almost there, but I can't get a cusp out of my surface, it follows the line I noted in the screenshot. SWX won't let me use a guide curve that goes between 2 points on the same profile, which it seems would solve the problem. Any suggestions? Greatly appreciated.
SWX 2010, SP3
SWX 2010, SP3
RE: OUT DAMN CUSP!
RE: OUT DAMN CUSP!
RE: OUT DAMN CUSP!
Thanks.
RE: OUT DAMN CUSP!
Can you attach your sldprt here?
One approach might be to get it all enclosed - then Knit solid.
Then Delete the face(s) and replace with a filled surface and re-knit.
RE: OUT DAMN CUSP!
Mostly different iterations in the sketch that goes around the top.
I'll have to model a similar case that represents the same problem to keep it safe.
RE: OUT DAMN CUSP!
Profiles were the loops around the top and bottom, guide curves connected the two.
Changed it, modeled as a 1/2 section
the lines that were guide curves, made them profiles
used the top and bottom as guide curves, no more cusp.
Made a boundary surface for the fillet that runs out at the end.
RE: OUT DAMN CUSP!
Certified SolidWorks Professional
RE: OUT DAMN CUSP!
RE: OUT DAMN CUSP!
Also, you are using a funky border edge to define your loft. Reconsider whether these are the curves that should actually define the u-v curves of your loft surface. Ideally, you would define a loft larger than you need with tamer u-v contours and then trim.
