Partition wall deflection criteria
We have always designed our partition support beams to meet the strict deflection requirements for the wall, using the wall and floor live loads. Ive been using panelfold's criteria forever, but noticed the other day these two lines which has me confused.
Can anyone shed any light on this? do the support beams only need to be designed to meet the deflection criteria for the weight of the wall and NOT the floor/roof live load, too?
the document reads:
"IT SHOULD BE UNDERSTOOD THAT THE LIMITS ABOVE RELATE ONLY TO DEFLECTION CAUSED BY LIVE LOADS RESULTING FROM THE WEIGHT OF THE PANELS AND THEIR POSITION IN THE OPENING."
which is seemingly contradicted by:
"OUR TRACK SYSTEMS ARE DESIGNED TO HAVE NEAR ZERO DEFLECTION DUE TO PANEL POSITIONING AND THEREFORE THE LIMITS SHOWN ABOVE ARE FOR THE SUPPORTING STRUCTURE EXCLUSIVELY."
the document reads:
RE: Partition wall deflection criteria
Here is the correct pdf.
http://
So it has little to do with structural deflection controls, that says can be overridden by hangers etc.
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
