DIFFERENCE BETWEEN BULKHEAD AND FRAMES...?
HI,
i am really confused with some a/c structure terminologies.listen fuselage consist of alot of frames and bulkheads.these both are the circular structure member and have 360' circumference. so how we can we really differentiate in a structure/diagram that this is frame and the other one is Bulkheads,.,.,.,.????
also tell the difference between Frames and Formers..???
waiting for the Repliesss
RE: DIFFERENCE BETWEEN BULKHEAD AND FRAMES...?
See attachment.
and yes, bulkhead could mean a heavy frame.
a bulkehead is the same circular structure, but with no hole. Sometimes these bulkheads act as a seperation, e.g.pressure bulkhead or fire bulkhead/wall.
Frame: always open. As mentioned, Boeing is big on frames, though they're not super-consistent in it. The Boeing frame doesn't actually touch the skin. The frame holds a collection of "shear-ties" (that do) and "stringer clips" that unsurprisingly clip into stringers.
The key bit of the fuselage frame is that it holds one or both of these types of structure in relative position. The frame, sheartie, and stringerclip buildup create a generic 'rib' that allows for the pressurization cycle by not creating any hardpoints.
Bulkhead: it can look almost exactly like a frame in that it can be open or not. The key difference is that stringer loads terminate on a bulkhead. Usually through fittings, and usually another set of fittings out the other side -- sometimes through a mating bulkhead. This is where sections meet or large structure comes to bear. As such, it almost always touches or defines the skin loft. The Frame sees no hat-section stringer loads aside what the stringerclips might introduce, the Bulkhead sees it all.
Former: This term is getting more 'airplay' than it once did. A Former most-often applies to direct attach to skin without Bulkhead load termination. What was once generally called a "rib". It generally does not tie to the stringers -- although sometimes it's clipped in. I think this is something the pressurized planes wanted to escape the Rib-word
Rib: Almost always ties to skin and usually clips to stringers when present. Usually, in an unpressurized plane, the attachment to skin and stringer is not a fatigue concern so a more generic term like 'rib' is often used.
Obviously, there are no hard and fast rules on this. Just some kind of legacy trends over the years.
Rule 1: when at Boeing, don't call a Frame a Rib. They love to catch people doing this.
Rule 2: everyone else seems to be less worried about it
muadib
