Block disappear .........
hi
I have a file have blocks with attribute , it can see.
But when I xref it to another file, it is disappear blocks. If I explode blocks it is OK. Do you now variables or... control it .
RE: Block disappear .........
But when I test a sample file same blockname , and xref file same block name it 's OK.
So I think maybe complex drawing ( too much object) make autocad confuse ?
Best regard,
So you may see the block filled out in the actual file but if you try reference it ... of course, you won't see anything because the properties associated to that line are invisible.
A simple test would be to do ddedit again and leave whatever he/she filled out and fill out the last line in the dialog box.
You'll see that you can see it in the actual file but you will see it the reference.
At least this is what your problem seems like ... I might be wrong.
let me know.
