Soldering of copper tubes for medical gases transportation
Recently i've been assigned to inspect a pipeline of medical gases in a cirurgy clinic. The medical gases involved was N2O and O2. The operation pressure of the pipeline will be alway below 7 kgf/cm2 (100 psi). Researching the correspondent technical data and norms, i've found it is recomended the so called "strong bending", "strong soldering" or "silver soldering" - wich is made with a temperature above 450°C (850°F), instead of the "weak soldering", "weak bending" or "tin soldering". My question is: what would be the effect of using this last one type of soldering?
RE: Soldering of copper tubes for medical gases transportation
Silver solder is more expensive, takes much more heat, free of bad things and much stronger.
http://ww
Whatever you're making, make sure you can either remove the flux or ensure it is compatible with your process gases. Some of the soft-solder fluxes are water-soluble but are pretty aggressive if left behind. Hard solder (silver solder) fluxes may require pickling and/or mechanical removal.
The fluxes used for "Tin-Soldering" can and will kill if inhaled, hence the large build up of Medical Gas Code, from the NFPA code.
Most required silver-solder must have a melting point above 1000* F, and usually a silver content above 15%. This of course runs the cost up, but the higher silver content ensures a better flow rate, less failure, and a cleaner joint.
There are also several tests that must be performed before said piping can be turned over and certified for use.
The "owner" of the building is foremost responsible for end results by said code.
